shanafan
May 03, 2020Apprentice
Netgear Armor doesn't show my router
Hello, I went to check out Netgear Armor's website, and when I signed into my Netgear account, it doesn't show my XR500 router appear. It says "No routers associated with this account." So, I...
shanafan
May 06, 2020Apprentice
Here is a screenshot of an error I get when I try to activate Netgear Armor.
Christian_R
May 06, 2020NETGEAR Employee Retired
Hi shanafan,
Can you clarify if you purchased a subscription or not. If so, from where? Or are you attempting to activate the NETGEAR Armor trial?
Thanks,
Christian
- shanafanMay 06, 2020Apprentice
I would like to do a trial, but I don't see the option.
Here are my steps:
1. Go to armor.netgear.com
2. Click Buy Now under the Nighthawk router picture
3. It goes to the Bitdefender store and it wants me to enter all my payment information and then click on Confirm Order.
How would I know I am getting the trial before clicking on Confirm Order?
- Christian_RMay 07, 2020NETGEAR Employee Retired
Hi Shanafan,
You will need use the Nighthawk app to activate Armor. I've provided details for that in the link below. However, you have an XR500 as stated in your original post and the XR500 currently does not support NETGEAR Armor. I have also included a link providing a list of routers that currently support NETGEAR Armor.
https://kb.netgear.com/000059442/How-do-I-activate-NETGEAR-Armor-using-the-Nighthawk-app
https://kb.netgear.com/000061281/Which-products-support-NETGEAR-Armor
Christian
- shanafanMay 07, 2020Apprentice
Ah, thanks Christian! That answers my question then (as far as the XR500 not working with Netgear Armor)
