drake19
Aug 17, 2019Follower
Netgear armor expensive. Is it worth it?
I intend on trying it when my antivirus subscription runs out. I already use BitDefender and Armor works through them anyway and it comes with an AV subscription as well. I've lit it up on ...
DexterJB
Aug 18, 2019NETGEAR Moderator
Hi drake19, welcome to the community! Thanks for giving us your feedback. Please do not hesitate to let us know if the issue will persist or let us know what you think about the feature.
Dexter
cfansoon
Nov 11, 2019Guide
I just bought the R7000P and activated armor, and subscripted the yearly plan.
In fact I also has Asus AC-RT68U (AiProtection) and Dlink Dir-2660(McAfee).
All three routers connected in series so that all internet traffics need to pass through all three routers with there different protections.
I also installed Norton Security on my MacBook, so in total there are 4 protections.
I should be very safe now?
- Orbi-RocNov 11, 2019Luminary
Hi cfansoon . It is to me, but you will no doubt find many contributors to this Community who feel otherwise. But bearing in mind that community forums such as this one mainly attract people with issues, I believe that the negative posts have to be kept in context.
I had a chance to try Armor with a free 90-day trial; and frankly, I was not impressed. I allowed the trial to expire and continued to follow Community posts to see how things were progressing. I think that the Netgear Armor/Bitdefender may have been launched a little bit prematurely and sufferred a lot of growing pain in the first few months.
Once I felt confident enough that most of the nicks had been ironed out, I bought the subscription. I'm pleased with Armor's performance. Is it perfect? No, but the most important issues I was confronted with during the trial have been taken care of. Armor will occasionally block valid URLs, but Bitdefender support offers an avenue to whitelist them if the user is 100% certain that the URL is not a threat. I haven't noticed any performance issues whatsoever. A key criticism for me was the absence of a narrative on threats blocked -- and this has been addressed by Armor/Bitdefender. When a threat is blocked, they now have a short explanation for it; and it's up to the user to take any follow-up action deemed necessary.
As far as pricing goes, when you consider that all phones, tablets, PCs and MACs, smart TVs and any other device connected to your network are protected, it's a bargain IMHO. Just to give you an example. I don't know of any antivirus software for Web OS, which is the operation system used for my LG TV. But knowing that I have that basic security scan always running at the router level (i.e. Armor), the TV is covered.
I do not have Bitdefender running on MacBooks. My experience with thrid party AV on MACs is that it causes problems, performance issues for the most part. If you query the Apple Support community forum, you'll find ample information on the subject. The only MAC AV that haven't caused me hiccups is ClamXAV, with Sentry activated. I had bought a liscense prior to Armor becoming available. I will likely not renew it when it runs out.
Did you use a trial (Armor) at first? If so, what was your experience like?
- cfansoonNov 11, 2019Guide
I am happy with my R7000P Armor, I also happy with my Asus's Trendmicro and Dlink's McAfee. Next I hope to get a Norton core router, I heard it is only available in US. Maybe later some other brand router will adopt Norton's protection and make available worldwide.
