Hutch33211's avatar
Hutch33211
Follower
Nov 26, 2019
Netgear Armor failed to subscribe
Netgear armor failed to subscribe
I have been trying to activate the Netgear armor trial on my Orbi but keep getting the error failed to subscribe. I can’t seem to find who to contact on this. It is a used router that I factory reset so not sure if that has something to do with it. Any ideas?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
  • Raxe500 (can't find it in drop-down above. Same armor subscription issue. Free trial worked fine. Paid subscription won't activate...says failed to subscribe. 8 days back an forth with support have done nothing.
  • Plase Could Someone Help. I Purchased RAX200, I Even PurchaEd 1 year Amour From The Netgear Armour Site. Everytime Failed To Subscribe!!! Not Sure Why My Text Here Is Case Sensitive, I am Using Android Z Fold 2, strange. Please Help Me Activate, Otherwise I Would Like £59 refund
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hi UnixSu,
      May you send me a private message and provide me with your email address and router serial number.
      Thanks,
      Christian
      • resch88's avatar
        resch88
        Does netgear even have a solution for this??? Spent two days after buying this from Costco and still get the failed to subscribe and have gotten zero help just a bunch of the same BS of restart your router re install app. Did it all. Are they going to provide answers?! So far the WORST customer service for a pricey product. Not satisfied at all. I opened a ticket and they closed it and said I had multiple open as well. I’m about to just return this.
  • I have the same problem 'failed to subscribe." Netgear support have no idea on how to fix this problem. I am definitely considering Linksys or other routers going forward. I have multiple cases open for this problem. They closed some of the cases without resolving them.
