jofomofo
Jul 12, 2024Aspirant
NetGear Armor for Windows 11
I bought a NetGear Armor subscription for my Orbi and the computers in my home. I installed it on the Orbi and most of the computers without issue. On one of my Windows 11 computers, it fails to ...
Jul 12, 2024Guru - Experienced User
Is this the only Windows 11 PC?
What build of Windows 11? 23H2?
Might check to see and temporarily disable any windows features from being install on the system that maybe preventing a SW installation. Check Privacy and Settings. Maybe disable any security apps or features temporarily.
jofomofo
Yes, I have several other Windows 10 and Windows 11 computers. NetGear Armor installed on all of them without issue.
This computer is running Windows 11 23H2 Build 22631.3880
I have disabled the only other security software on the machine, Windows Defender and temporarily turned off all of its features including firewall and active protection. No change in behavior. Machine still reboots every time I try to install NetGear Armor.
- FURRYe38Jul 12, 2024Guru - Experienced User
This one PC needs to be looked into then. If others installed correctly with out issues, this one PC needs to be checked.
Take a look at the Event logs for windows to see if it's reporting anything.
Check with the Mfr of the motherboard or MS in regards to this.
