jofomofo
Jul 12, 2024Aspirant
NetGear Armor for Windows 11
I bought a NetGear Armor subscription for my Orbi and the computers in my home. I installed it on the Orbi and most of the computers without issue. On one of my Windows 11 computers, it fails to ...
Jul 12, 2024Guru - Experienced User
Is this the only Windows 11 PC?
What build of Windows 11? 23H2?
Might check to see and temporarily disable any windows features from being install on the system that maybe preventing a SW installation. Check Privacy and Settings. Maybe disable any security apps or features temporarily.
jofomofo
I just went to the netgear.armor.com support site and clicked on this link to search their Knowlege Base about Armor.
https://www.netgear.com/support/product/netgear-armor.aspx
I got a 404 page not found error for that link from the support site. Not encouraging.
- KevinLiTJul 12, 2024NETGEAR ModeratorHello jofomofo,
Welcome to the NETGEAR Community!
I understand that you have a custom computer build and would like to use our knowledge based articles for additional information on how to fix this issue.
Please use the following link for additional information on your NETGEAR Armor's features and recommended installation guides:
https://www.netgear.com/support/product/armor/#configurationassistance_commontopics
Please visit the following knowledge article on how install Bitdefender on devices that are connected to your router (this includes your custom PC):
https://kb.netgear.com/000061291/How-do-I-install-Bitdefender-Security-on-the-go-protection-on-my-devices
Best,
Kevin
Community Team
