Dustin_V
Apr 18, 2019NETGEAR Employee Retired
NETGEAR Armor Frequently Asked Questions
With cyber threats becoming more and more prevalent, it’s important to know that there are options to help keep you, your family, and your data safe. NETGEAR Armor is designed to help keep you sa...
pedrseymour
Apr 26, 2019Initiate
I've already paid for a BitDefender subscription. Will I get a credit for the time not used?
DexterJB
Apr 28, 2019NETGEAR Moderator
Hi pedrseymour, thank you for your inquiry. The NETGEAR Armor is separate subscription from your other Bitdefender products. You may also check with Bitdefender support linked below for your additional subscription queries.
https://www.bitdefender.com/consumer/support/
Dexter
