Dustin_V
Apr 18, 2019NETGEAR Employee Retired
NETGEAR Armor Frequently Asked Questions
With cyber threats becoming more and more prevalent, it’s important to know that there are options to help keep you, your family, and your data safe. NETGEAR Armor is designed to help keep you sa...
Orbi-Roc
May 24, 2019Luminary
Netgear Armor as a standalone app on the router works fine for me. I removed Bitdefender Total Security from both Win10 PCs and Macs; and have it running on one iPod Touch in order to have continued access to email leaks.
In my experience, AV software is useless on a Mac, except perhaps for ClamXav.
But I tried BD Total Security on my Mac any way, just to see how it would perform; and the outcome was not satsifactory at all. Although I had no issues with the network printer, the App Store suddently became inaccessible for both purchases and updates; and iMessages became unstable. Removing BD Total Security from the Mac brought everything back to normal.
In light of your experience and mine, I think that we can all agree with the tech support person you dealt with: YES, Netgear Armor is indeed a work-in-progress, and we are the guinea pigs.
ScottBLA
May 24, 2019Guide
Update: Since resetting BD and re-enabling Armor on the router, everything seems to be working okay now. I haven’t run into any more issues. Not sure if there was an update that fixed it, or it’s just buggy, but so far so good.
