Dustin_V
Apr 18, 2019NETGEAR Employee Retired
NETGEAR Armor Frequently Asked Questions
With cyber threats becoming more and more prevalent, it’s important to know that there are options to help keep you, your family, and your data safe. NETGEAR Armor is designed to help keep you sa...
Orbi-Roc
Oct 11, 2019Luminary
Hi Stev3D . This is an older post, so perhaps you already found your answer elsewhere. As far as I know, there is only one price which is inclusive of Bitdefender Total Security. But as I pointed out in an earlier post, Armor can be used as a standalone application on the router only, which will protect all your computers and other devices WHILE CONNECTED TO YOUR NETWORK.
Stev3D
Thank you for the clarification.
