Dustin_V
Apr 18, 2019NETGEAR Employee Retired
NETGEAR Armor Frequently Asked Questions
With cyber threats becoming more and more prevalent, it’s important to know that there are options to help keep you, your family, and your data safe. NETGEAR Armor is designed to help keep you sa...
riodwardlx
Mar 10, 2020Initiate
I have the Nighthawk R7000 AC1900. I purchased the Armor coverage at the end of the trial period, however, on the app, and if I login from my laptop, it shows "Expired". I have not found anywhere to put in an activation code. Both modes (app or laptop) simply take me to the sight that says "Thank you for purchasing Netgear Armor!" and then offers me an opportunity to purchase it again.
Any wisdom is welcome. I appreciate it. Thanks.
riodwardlx
- Christian_RMar 11, 2020NETGEAR Employee Retired
Hello riodwardlx,
May you send me a private message with your email address and serial number and confirm if you purchase your Armor subscription using the app or web portal.
Thanks,Christian
- CAR1954May 13, 2020Aspirant
I have the same issue. Paid for the Armor subscription, got the email and it works online, but when you go to the router with the ORBI interface, it says expired and continues to take me to buy it again.
- Christian_RMay 15, 2020NETGEAR Employee Retired
Hi CAR1954,
May you let us know how you purchased the Armor subscription (ex. Orbi app, website, etc.)?
Christian
