Dustin_V
Apr 18, 2019NETGEAR Employee Retired
NETGEAR Armor Frequently Asked Questions
With cyber threats becoming more and more prevalent, it’s important to know that there are options to help keep you, your family, and your data safe. NETGEAR Armor is designed to help keep you sa...
DexterJB
Apr 28, 2019NETGEAR Moderator
Hi SimonBelgium, you can use the Nighthawk/Orbi app (whichever supports your device) then go to Settings > Security > Toggle if Off.
Dexter
Ngearvictim
May 27, 2020Guide
There is no such toggle in my app, or on my Orbi admin page.
please help me disable this theftware!!,
