Dustin_V
Apr 18, 2019NETGEAR Employee Retired
NETGEAR Armor Frequently Asked Questions
With cyber threats becoming more and more prevalent, it’s important to know that there are options to help keep you, your family, and your data safe. NETGEAR Armor is designed to help keep you sa...
pedrseymour
Apr 26, 2019Initiate
I've already paid for a BitDefender subscription. Will I get a credit for the time not used?
ObiWanKenobi47
Nov 16, 2020Aspirant
I'm using Netgear's Armor with my Orbi mesh router. Armor told me that I had a number of vulnerabilities on an older shared network drive that was considered "legacy" by the manufacturer so I replaced it and removed it from my network. The problem is that the vulnerability list is not updating to remove those vulnerabilities from the removed device. How do I force an update?
