Dustin_V
Apr 18, 2019NETGEAR Employee Retired
NETGEAR Armor Frequently Asked Questions
With cyber threats becoming more and more prevalent, it’s important to know that there are options to help keep you, your family, and your data safe. NETGEAR Armor is designed to help keep you sa...
Retired_Member
Feb 21, 2021I am about to jump wagon, ditch NETGEAR my R8000P, and get UniFi Dream Machine because it offers much more feature-wise and security-wise than NETGEAR stock firmware. I care about hardware-based features, such as creating my own Netfilter/IPTable rules and VLAN isolation.
If NETGEAR Armor is a router-based app, then does it add stronger device isolation or stringest packet inspection? Is NETGEAR Armor anything other than a gimmick that adds an easy-to-use app to bloat the router?
