Dustin_V
Apr 18, 2019NETGEAR Employee Retired
NETGEAR Armor Frequently Asked Questions
With cyber threats becoming more and more prevalent, it’s important to know that there are options to help keep you, your family, and your data safe. NETGEAR Armor is designed to help keep you sa...
pedrseymour
Apr 26, 2019Initiate
I've already paid for a BitDefender subscription. Will I get a credit for the time not used?
bhenriquez
Aug 01, 2021Aspirant
I had the same question, called and talked to both Netgear and Bitdefender, you won't get any credit.
