wealth-secure
Aug 16, 2023Aspirant
NETGEAR Armor is not showing my router on web browser
Hi. I have had a Netgear RAX40 router for a while now, and upon initial installation and getting an Armor subscription it was working just fine, showing up on the web page for armor, etc. The app too...
DEUTSCHECLUB
Aug 25, 2023Aspirant
It appears that you're encountering difficulties with your Netgear RAX40 router's association with your Armor account. Initially, the router was functioning well and visible on the Armor web page and app. However, after switching phones, the app became unusably slow, prompting you to rely on the web version. Regrettably, the web version now indicates that there are no routers linked to your account, despite displaying devices and Armor alerts correctly. This situation has left you unable to control and monitor your network as intended.
- wealth-secureAug 25, 2023Aspirant
Yes, that is indeed the case. This is leading me to seriously reconsider using any Netgear routers.
Another problem has showed up and that is that the logs of Netgear Armor (both from the website and from the app when I do manage to load it) do not correlate. Netgear Armor gives me notificatoins every now and then that it has successfully stopped a port scnning attack on my Nvidia Shield but when I check the logs of my actual router itself they show continuous 'LAN access from remote IP' towards my Nvidia Shield. Literally multiple each minute.
Because these logs are very limited in detail, I cannot make out if these were successful remote access attempts or if they were blocked. And it is weird because they continue to happen even if I pull the ethernet cable and power cord out of the device that is assigned that specific internal IP.
