MackyG
Oct 12, 2023Aspirant
NETGEAR Armor is not showing my router
I am having this same issue on my RAX200. Anyone have a solution to this?
Oct 12, 2023Guru - Experienced User
Be sure FW is up to date on the Router.
Be sure your using latest version of the Nighthawk app:
How too:
Might Factory reset the router and setup from scratch using either a PC and web browser then log in to the router using the NH app and check Armor status here. Or setup from scratch with the NH app.
- MackyGOct 12, 2023Aspirant
I had to revert 3 firmwares behind as the most recent firmware DEC 2022 caused the router to malfunction by dropping internet every 10 minutes. During that time I factory reset it and I am just noticing now that armor is having issues on the web portal.
- FURRYe38Oct 12, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.- MackyGOct 12, 2023Aspirant
It's a Rogers XB7 model. I believe it is CGM4331ROG. I am using a cat6 cable yes.
