Dustin_V
Jul 17, 2018NETGEAR Employee Retired
NETGEAR Armor is now available!
NETGEAR Armor is now available on the Nighthawk R6900P and R7000P routers! With NETGEAR Armor’s advanced protection, you will be able to actively detect and protect your home and family fr...
HodaS
Aug 06, 2018NETGEAR Employee Retired
Thank you for your feedback, we have updated our website with the pricing information, please check it out at https://www.netgear.com/landings/armor/
We believe that NETGEAR Armor is well beyond a router security solution, it's a whole network peace of mind provided and is backed by Bitdefender - a leading provider of security solutions. The service is free to try for 90-days on R7000P and R6900P routers for now. After the trial period, subscription of $69.99/year includes a subscription to Bitdefender Total Security 2019 package for unlimited devices.
We appreciate our customers’ interest in having NETGEAR Armor coverage on more and more NETGEAR products. And that is why we are evaluating adding NETGEAR Armor to other NETGEAR products based on popularity.
Thank you again for your feedback.
beotto
Apr 03, 2019Guide
i activated it yesterday and it stopped all my devices from working.
i disable but my google devices and meros light buld still does not works.
how to deactivate all armor in my router ?
- beottoApr 04, 2019GuideHi ! I tried the factory reset ! reinstalled everything but the armor installs itself without my permisson on the app and all my google and smart devices still does not works. anyone experiencing the same behavior ? it is frustrating. thanks and any other help is greatly apreciated. cheers bruno
- ErnestTheGreatApr 04, 2019NETGEAR Employee Retired
beotto You can actually disable it from the app. Open up your Orbi App go to Settings then Security and on security screen you will see a option to Enable NETGEAR Armor click on the toggle switch to disable Armor.
i ve already tried to disable it ... the problem is that aftert disabling it it still shows armor is activated !!!
