Dustin_V
Jul 17, 2018NETGEAR Employee Retired
NETGEAR Armor is now available!
NETGEAR Armor is now available on the Nighthawk R6900P and R7000P routers! With NETGEAR Armor’s advanced protection, you will be able to actively detect and protect your home and family fr...
ErnestTheGreat
Apr 04, 2019NETGEAR Employee Retired
beotto You can actually disable it from the app. Open up your Orbi App go to Settings then Security and on security screen you will see a option to Enable NETGEAR Armor click on the toggle switch to disable Armor.
beotto
Apr 04, 2019Guide
i ve already tried to disable it ... the problem is that aftert disabling it it still shows armor is activated !!!
