Dustin_V
Jul 17, 2018NETGEAR Employee Retired
NETGEAR Armor is now available!
NETGEAR Armor is now available on the Nighthawk R6900P and R7000P routers! With NETGEAR Armor’s advanced protection, you will be able to actively detect and protect your home and family fr...
mlopez317
May 17, 2019Aspirant
i downloaded the app but when i looke on the dashboard for the security setting to activate armor its not there
- DexterJBMay 19, 2019NETGEAR Moderator
Hi mlopez317, welcome to the community! Please make sure that your router is set to router mode and not on AP mode. The link below shows how to setup the router n AP mode but you can use the guide to switch it over to router mode.
Dexter
- mlopez317Oct 21, 2019Aspirant
brought a net gear router under armor but i used my email mlopez317@outlook.com but i registered my nighthawk 7000 router on my other *****@hotmail.com how do i deregister it from *****@hotmail.com and reregister my router to *****@outlook.com havent recieved a response from customer sevice
- Orbi-RocOct 21, 2019Luminary
Hi mlopez317 . I think your best bet is to contact Bitdefender Support directly. I've had immediate success using the Chat functionality at https://www.bitdefender.com/consumer/support/ .
And one more thing -- I don't think it's a good idea to post email addresses in a public forum such as this one. While you can do so in the context of a private Chat session with Bitdefender Support, or a Private Message with a moderator on this forum, including email addresses in a public forum can attract all sorts of spam mail. I hope that moderator will chime in and edit your post to delete the email addresses.
