Dustin_V
Jul 17, 2018NETGEAR Employee Retired
NETGEAR Armor is now available!
NETGEAR Armor is now available on the Nighthawk R6900P and R7000P routers! With NETGEAR Armor’s advanced protection, you will be able to actively detect and protect your home and family fr...
GrandOak01
Oct 21, 2019Guide
Largest issue is finding support on BitDefenders Website, which is primarily focused on their general products. It's gotten better with some info on NetArmor, but has a ways to go. Also Nebulous on what sign-in to use when installing on devices. Do they create their own or use master from route.
- DexterJBOct 21, 2019NETGEAR Moderator
Hi GrandOak01, you will need to use your SSO account with NETGEAR for your Armor subscription.
Dexter
