CanadianGuy
Jan 02, 2022Guide
Netgear Armor no longer enabled, even though subscription active
Netgear Armor is listed in the dashboard (192.168.1.1) as not enabled, even though armor.netgear.com says its still active. Even though this is a currently paid-for service, I have no other way to ac...
CanadianGuy
Jan 10, 2022Guide
Ended up finding through community support that I should just try toggling Netgear Armor 'enable' button off, then on again in the Netgear app, and it did work :) Apparently the desktop UI can't control that--it's app-only control for that feature.
Thanks for taking the time to respond!
Chris
