-SlowJoe-
Jul 31, 2022Apprentice
Netgear Armor Not Recognizing Bitdefender for Armor on Mobile Devices
Netgear Armor has been really solid for me the last 6-7 months since purchasing my RAXE500. Before I get into the issue, my modem (CM2000), and router (RAXE500) firmware are fully up-to-date. My iOS ...
Jeffgear
Nov 09, 2022Virtuoso
I had another follow up call from NG Support. After recalling the full history for about an hour and sending through more screen shots from the Orbi app and iOS Bitdefender, and being put on hold as the agent conveyed my updates back to someone else, I was told the issue will be resolved in the next Orbi app update, and my case would now be closed.
Given I’ve been through a few Orbi app, Bitdefender app and iOS updates over the last year (and with hindsight did the unnecessary nuke option of factory resetting my router) during which time this issue has been apparent, I’m not entirely convinced it will be resolved in an impending Orbi app update, but I’ll reserve a degree of optimism that the person working behind the scenes is enlightened about the root cause and the app development fixes that are forthcoming.
-SlowJoe-
Nov 09, 2022Apprentice
Wow, maybe some movement?!
Think your skepticism is warranted for sure and I’m with you on it. Hopefully we’re wrong though.
No movement on my end.
