-SlowJoe-
Jul 31, 2022Apprentice
Netgear Armor Not Recognizing Bitdefender for Armor on Mobile Devices
Netgear Armor has been really solid for me the last 6-7 months since purchasing my RAXE500. Before I get into the issue, my modem (CM2000), and router (RAXE500) firmware are fully up-to-date. My iOS ...
BK1959
Dec 03, 2022Star
Another quirky issue in the Orbi app: protection level is down to 74 or 71 because I haven’t “turned on security notifications”. But all notifications have been turned on!
The latest app update hasn’t solved any of the problems.
- JeffgearDec 03, 2022VirtuosoJust seen a new Orbi app update - version 2.21.1.353 - sadly this hasn’t resolved the Armor Security issue with the iOS Bitdefender app. Maybe they focussed on the connectivity bugs that have surfaced. Meanwhile the Bitdefender app remains on version 4.0.0 after 7 months.
The odd thing now is the Security score log is fluctuating between 84 and 88 each day, repeating the same messages reporting that I have turned on or indeed turned off security notifications - which is mistaken as it has always been turned on in my iOS settings.- BriansfDec 04, 2022Apprentice
I have the RAX-80 router and I get the same thing. My security fluctuates also. My security notifications are always on. Must be buggy software.
It's not just the Orbi App! I'm running the RAX-80 router and I get the same thing. I'm using the Netgear Nighthawk App with Bitdefender. My notifications are also turned on and I get the same thing. Security level changes from 81 to 79. I'm at the point where I don't even to look at it anymore! Just checked and no updates available. Does Bitdefender or Netgear care?
