-SlowJoe-
Jul 31, 2022Apprentice
Netgear Armor Not Recognizing Bitdefender for Armor on Mobile Devices
Netgear Armor has been really solid for me the last 6-7 months since purchasing my RAXE500. Before I get into the issue, my modem (CM2000), and router (RAXE500) firmware are fully up-to-date. My iOS ...
BK1959
Dec 03, 2022Star
Another quirky issue in the Orbi app: protection level is down to 74 or 71 because I haven’t “turned on security notifications”. But all notifications have been turned on!
The latest app update hasn’t solved any of the problems.
Briansf
Dec 04, 2022Apprentice
It's not just the Orbi App! I'm running the RAX-80 router and I get the same thing. I'm using the Netgear Nighthawk App with Bitdefender. My notifications are also turned on and I get the same thing. Security level changes from 81 to 79. I'm at the point where I don't even to look at it anymore! Just checked and no updates available. Does Bitdefender or Netgear care?
