-SlowJoe-
Jul 31, 2022Apprentice
Netgear Armor Not Recognizing Bitdefender for Armor on Mobile Devices
Netgear Armor has been really solid for me the last 6-7 months since purchasing my RAXE500. Before I get into the issue, my modem (CM2000), and router (RAXE500) firmware are fully up-to-date. My iOS ...
Briansf
Dec 06, 2022Apprentice
Ya I'm getting tired of this flakey software. Seems to change almost everyday! Bitdefender installed, Bitdefender not installed, Your score dropped because you have not turned on notifications, Your score increased because you turned on notifications. Will be ending my subscription soon. Will be going to another protection service. One that has American (English) support.
Jeffgear
Dec 06, 2022Virtuoso
I spoke too soon! Orbi is now saying I have notifications turned off and reduced my security score accordingly.
Another quirk - I moved my work mobile and laptop to my guest network in the hope the laptop is no longer correctly reported as being eligible for Bitdefender. I can’t install a 3rd party app anyway and it has an enterprise grade endpoint protection anyway. I would have thought the Guest network was excluded from the Bitdefender check as guest endpoints are transient and should be excluded from this check. Yes scanning them for vulnerabilities is good but exclude from the Bitdefender agent and not let them impact the security score unless they of course have vulnerabilities.
Come on Armor - please sort your Bitdefender and Orbi integration as well as iOS.
