-SlowJoe-
Jul 31, 2022Apprentice
Netgear Armor Not Recognizing Bitdefender for Armor on Mobile Devices
Netgear Armor has been really solid for me the last 6-7 months since purchasing my RAXE500. Before I get into the issue, my modem (CM2000), and router (RAXE500) firmware are fully up-to-date. My iOS ...
Jeffgear
Dec 07, 2022Virtuoso
I spoke too soon! Orbi is now saying I have notifications turned off and reduced my security score accordingly.
Another quirk - I moved my work mobile and laptop to my guest network in the hope the laptop is no longer correctly reported as being eligible for Bitdefender. I can’t install a 3rd party app anyway and it has an enterprise grade endpoint protection anyway. I would have thought the Guest network was excluded from the Bitdefender check as guest endpoints are transient and should be excluded from this check. Yes scanning them for vulnerabilities is good but exclude from the Bitdefender agent and not let them impact the security score unless they of course have vulnerabilities.
Come on Armor - please sort your Bitdefender and Orbi integration as well as iOS.
Briansf
Dec 13, 2022Apprentice
Here's a new one. For some reason Netgear Nighthawk app stoped recognizing my iPhone 13! This came out of the blue for no reason! It now says it's a iPhone 14.5! It said I had to log in to use the app. When I tried it said that my device was not recognized and that I had to have a push notification sent to my phone! Tried that with no luck. The other option was to have a code sent to my e-mail which I tried. That e-mail was sent to junk folder. I deleted the Nighthawk app from my iPhone 13 and reinstalled it. No luck. Still showed that the iPhone as not recognized by the app. Had the code sent again and checked my junk folder and found the code. Good to go?...nope! Now it says I have reached my 5 device limit and I have to delete a device. So I deleted the iPhone device and it installed on my iPhone just fine...with the original problems still there! This stuff would drive a squirrel nuts! I think I'm going to go on a long vacation!
- JeffgearJan 06, 2023VirtuosoThe new Orbi app update this week (2.22.0.247) hasn’t resolved the two bugs with Armor for iOS devices (although Android users are now reporting these). These bugs are iOS devices not being recognised as protected despite running the Bitdefender app and VPN, and Armor/Orbi thinking security notifications is disabled when notifications are enabled in both the Orbi and Bitdefender apps. Both of these issues impacts and misreports the security score shown in Orbi. I suspect they are related in that it thinks my iOS devices are not protected, one of these being my iPhone running the Orbi app itself, and therefore the Orbi or Bitdefender app cannot parse the notification status from iOS to the Orbi app’ Security function. Logging out of Bitdefender and back in, temporarily resolves the notifications issue for a day or so.
- BriansfJan 07, 2023Apprentice
I was hoping that a fix was on the way. I'm now only using netgear nighthawk app to check if anyone is logged on to my network. Using Bitdefender app for scanning my devices. Is netgear/bitdefender aware of this issue? and if so are they doing anything about it?
it's like they don't care.
