-SlowJoe-
Jul 31, 2022Apprentice
Netgear Armor Not Recognizing Bitdefender for Armor on Mobile Devices
Netgear Armor has been really solid for me the last 6-7 months since purchasing my RAXE500. Before I get into the issue, my modem (CM2000), and router (RAXE500) firmware are fully up-to-date. My iOS ...
Briansf
Mar 25, 2023Apprentice
I feel your frustration. However I and others have received an E-Mail saying that they aware of the problem and a fix should come soon. It will be a fix over the internet and no user intervention will be needed. However all modules are still working and protecting your products. Hopefully it will be soon when a fix will come.
Briansf
May 16, 2023Apprentice
It does seem to be a long time to fix such a small problem. I’ve said in the past that if the problem persists when my subscription expires I’ll be going to another product. When Apple, Microsoft and other large companies have software issues they seem to usually issue a fix within days if not hours. Bit Defender for Nighthawk is over a year old and counting with no updates! That sounds crazy to me.
