VerneArase's avatar
VerneArase
Apprentice
Dec 04, 2021
Netgear Armor on 2021 MacBook Pro 16
I have Netgear Armor on a RBK853 system, and have installed it on all my computers.
Unfortunately, I've had to deinstall BitDefender from my 2021 MacBook Pro because there was no way to configure BitDefender to stop deleting the following from backups of CrossOver.app:
directory: /Volumes/Backup/Applications/CrossOver.app/Contents/SharedSupport/CrossOver/lib/wine
files:
mofcomp.exe
wmplayer.exe
The wmplayer.exe is from memory because apparently BitDefender deleted wmplayer.exe from the original source CrossOver directory in /Applications as well.
Does anyone know how to get Netgear Armor support?
It looks like BitDefender only supports their own users - is there some place where I can get equivalent support through NetGear Armor?
This is incredibly frustrating - sure you can install BitDefender on all your computers, but how do you get support when things go wrong?
-- Thanks, Verne
1 Reply
