gaquino18
Aug 25, 2019Follower
Netgear Armor on Nighthawk X10
Does anyone know if there is a way to use NETGEAR Armor in my Nighthawk X10? I don’t see the Security option on my App.
myersw
Aug 25, 2019Master
Needs to be part of the firmware build and Netgear is being selective as to what routers are Armor supported. Have not seen and of the XA routers supported, could be wrong.
QARABO
Jan 04, 2020Aspirant
I have the X10 R9000 router, was hoping to use the new Armor app but its not available.You would think this router being the top of the line that Netgear would gove you the option of subscribing to the Armor App.
- Jah1379Feb 11, 2020AspirantNetgear sucks for our X10 routers. No Netgear Armor, No DumaOS. I contacted them and no firmware update for the Netgear AD7200 :-(
