horizonjob
Apr 17, 2020Tutor
Netgear Armor option not showing in app
I'm not sure what I am missing. I have a Bitdefender Box 2 and figured it would be better to remove one extra appliance that could affect speed, so I would just subscribe to Netgear Armor. The proble...
Christian_R
Apr 20, 2020NETGEAR Employee Retired
Hi horizonjob,
Welcome to the community! Would you mind reinstalling the Nighthawk app and following the article linked below. Also, may you tell me whether your R7000 is in router or access point mode.
https://kb.netgear.com/000059442/How-do-I-activate-NETGEAR-Armor-using-the-Nighthawk-app
Thanks,
Christian
- horizonjobApr 21, 2020Tutor
Thanks, Christian. Reinstalling the app doesn't help. The R7000 is in bridge/AP mode because it is hooked up to a BitDefender Box 2. I have a current BitDefender subscription through the Box, but was thinking of ditching the hardware firewall when the subscription runs out in a few months. The Box has worked fine and it should not be causing any real lag since it is connected to my fiber modem by Ethernet cable and to my R7000 by another Ethernet cable, but removing the Box will give me one less potential point of failure.
- Christian_RApr 22, 2020NETGEAR Employee Retired
Hello horizonjob,
May you try setting the R7000 is router mode and letting us know if you're able to activate Armor using the Nighthawk app.
Thanks,
Christian
- horizonjobApr 28, 2020Tutor
Thanks, Christian. I will try that. However, since my BitDefender Box took awhile to set up and required assistance from their customer support, I think I will wait until my Box subscription expires in a few months so I do not risk having it stop working when I take my Nighthawk out of bridge mode and then put it back on bridge mode later. Besides, if I already have BitDefender defending all my devices on the current Box subscription, I would not want to be paying twice for the same protection.
Christian_R wrote:Hello horizonjob,
Thanks,
Christian
