kc6108
Jul 27, 2022Luminary
Netgear Armor Outage?
Is Netgear experiencing issues with Armor ATM? None of our devices (dozens of them, of all flavors… iPhones, Google Chromecast w/ Google TV, etc etc etc etc) can play YouTube videos. You can load YouT...
- Jul 28, 2022I figured it out! Using Cloudflare’s 1.1.1.1/1.0.0.1 DNS servers in Internet Setup were causing all my problems. I switched to the option of using my Internet provider’s.
I don’t know why using 1.1.1.1/1.0.0.1 was causing problems in the Orbi and RAX120 setups. The R9000 setup wasn’t using 1.1.1.1/1.0.0.1, but it wasn’t configured to use Netgear Armor functionality, have the service activated, and maybe not even have the functionality as an option in the first place… can’t remember. Both setups use Sparklight Internet via a DOCSIS 3.1 modem… and Sparklight has 3.1 configured on their end.
Update: Just had another customer run into this issue… using an Orbi, Armor, and 1.1.1.1/1.0.0.1. That makes three.
Is it Sparklight? Is it 1.1.1.1? Is it Armor? Don’t know, but not using 1.1.1.1 fixes the issue.
Hope this helps someone else.
Jul 28, 2022Guru - Experienced User
What happens if you disable Armor in the NH app, then power OFF the RAX120 then back On. Does streaming work then?
