jimyjames's avatar
jimyjames
netgear armor r7000p bitdefender
got a new router
Nighthawk R7000P / ac2300 smart wifi router / MU-MIMO
Firmware Version V1.3.1.44_10.1.23
turned on the netgear armor
NETGEAR Armor Status
Status:  Protected
NETGEAR Armor services will expire in 76  days
on boot i get a log entry saying [BitDefender] Bitdefender activats succesfully, but the user_token and device_id are lost
looking for clarification on what this means. does it affect my protection? if so, how do i fix it?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi jimyjames,
    Welcome to the community!
    I have sent you a message. Please check your inbox.
    Dexter
    Community Team
    • dcrabtree's avatar
      dcrabtree
      Having the same issue with R6900P router. What was your solution?
