William_Mo
Mar 25, 2024Tutor
Netgear Armor setup App lock
Hello there, I had applied the app lock function in Netgear Armor to the Android Apps. However, with several app updates, I couldn't find the same function in the Orbi Netgear Armor page. I woul...
Apr 02, 2024Guru - Experienced User
Remember where this app lock feature was located in the Armor app?
Is this for Nighthawk or Orbi Armor?
Sounds like it was moved to a different location, sub menu setting or possible Armor removed this feature.
- William_MoApr 02, 2024Tutor
Hi, thank you for the response:
I remembered activated it in Armor app.
Orbi Armor.
Probably removed this features, since I couldn't find it anywhere in the app.
