tn12
Apr 05, 2023Aspirant
Netgear Armor tied to previous owner
I purchased a refurbished Orbi Mesh system, and was able to successfully register it. However, in the Orbi app under Armor, another email address is listed. I have no way to remove it, is there a mod...
Apr 06, 2023Guru - Experienced User
You may need to reach out to NG support:
You might send the email address you see there a message using that email address and ask to see if whom ever responds can also get it removed.
- Brainjohn011Apr 06, 2023Aspirant
FURRYe38 wrote:You may need to reach out to NG support:
https://community.netgear.com/t5/NETGEAR-Armor/Armor-Help-and-Information/td-p/2211063/jump-to/first-unread-message/ click
Thanks for providing link to NG support.
- tn12Apr 14, 2023Aspirant
After waiting a week for a response (after being ghosted on the chat several times), this is what I got:
āIf your Netgear router is still registered to someone else's Armor account, you will need to contact the reseller and inform them to have the owner unregister the router from their armor Account in order to remove the router.ā not super practical.
The armor icon on the web url says not active, just the armor tab on the iOS app. Does that give the ability for the previous owner to log in remotely or monitor traffic?
- FURRYe38Apr 18, 2023Guru - Experienced User
If the router wasn't deregistered from there account, I would think there is that possibility.
I recommend you factory reset the router and setup from scratch with the router disconnected from the ISP modem/ONT, and use a wired PC and web browser to set up the router first. Once it's setup, connect it to the ISP Modem/ONT. Avoid using the mobile app to activate any Armor services.
Make contact with the seller to have them remove the router from there account or make contact with NG support and have them remove it and get it registered to you.
- tn12Apr 18, 2023Aspirant
I factory reset it prior to setting it up, it is even registered to my account. In the web app, the armor status is "not activated". It is just the iOS app that is odd, since once I go that tab is says that Armor is registered to another account.
- HasnainmirMar 24, 2024Tutor
https://community.netgear.com/t5/NETGEAR-Armor/Armor-Help-and-Information/td-p/2211063/jump-to/first-unread-message click
Thank you for providing the link but they haven't replied to my query yet
