tn12
Apr 05, 2023Aspirant
Netgear Armor tied to previous owner
I purchased a refurbished Orbi Mesh system, and was able to successfully register it. However, in the Orbi app under Armor, another email address is listed. I have no way to remove it, is there a mod...
Apr 06, 2023Guru - Experienced User
You may need to reach out to NG support:
You might send the email address you see there a message using that email address and ask to see if whom ever responds can also get it removed.
Brainjohn011
Apr 06, 2023Aspirant
FURRYe38 wrote:You may need to reach out to NG support:
https://community.netgear.com/t5/NETGEAR-Armor/Armor-Help-and-Information/td-p/2211063/jump-to/first-unread-message/ click
Thanks for providing link to NG support.
