tn12
Apr 05, 2023Aspirant
Netgear Armor tied to previous owner
I purchased a refurbished Orbi Mesh system, and was able to successfully register it. However, in the Orbi app under Armor, another email address is listed. I have no way to remove it, is there a mod...
Apr 18, 2023Guru - Experienced User
If the router wasn't deregistered from there account, I would think there is that possibility.
I recommend you factory reset the router and setup from scratch with the router disconnected from the ISP modem/ONT, and use a wired PC and web browser to set up the router first. Once it's setup, connect it to the ISP Modem/ONT. Avoid using the mobile app to activate any Armor services.
Make contact with the seller to have them remove the router from there account or make contact with NG support and have them remove it and get it registered to you.
tn12
Apr 18, 2023Aspirant
I factory reset it prior to setting it up, it is even registered to my account. In the web app, the armor status is "not activated". It is just the iOS app that is odd, since once I go that tab is says that Armor is registered to another account.
