Yocal9
Apr 12, 2019Follower
Netgear Armor URL exclusions or whitelisting
Is it possible to add URL exclusions or whilelist sites with Netgear Armor? I've activated it on my RBR50 Orbi system and there are URLs that I need to get to and mobile apps that need access that Ar...
- Jun 23, 2020
Adding my me too here. This is ridiculous! Really who though it would be a good idea to block sites you think might be suspicious, but have no way to bypass the block. You are blocking a number of sites I need access to, and I have no intention of submitting them to you to review or approve, I want them, I need them, you need to let me bypass the block. This is completely unacceptable.
I just finally got the system all set up the way I like, but I'm about to return it, because this is a deal breaker... YOU NEED TO FIX THIS QUICKLY!edit: sorry I was getting really upset about this because I'm on a time crunch and things were blocked. I figured out in the orbi app, it notfies that it blocked sites, if you click on the notification there is the option to unblock.
It is still a bit ridculous that I cant just click procced on the web page, and I didn't have my phone near or think about looking on the phone to unblock sites Im working on on my main PC.
steiningernc
Oct 06, 2019Initiate
There is no reason you should not be able to continue once warned. I will be disabling my permanently because you cost me a very important work meeting with the military because you blocked it. Then I just tried paying a garbage bill of a local company and I can't. This is very poor customer service.
AlexK17
Feb 12, 2020Initiate
This is crazy. There should be an option for me to whitelist things I want on my own router. I shouldn't have to submit it to Netgear to review. I'm not asking you to whitelist something globally. It is my network, it is my choice. If I want to visit this site, then I should be able to.
