Yocal9
Apr 12, 2019Follower
Netgear Armor URL exclusions or whitelisting
Is it possible to add URL exclusions or whilelist sites with Netgear Armor? I've activated it on my RBR50 Orbi system and there are URLs that I need to get to and mobile apps that need access that Ar...
- Jun 24, 2020
Adding my me too here. This is ridiculous! Really who though it would be a good idea to block sites you think might be suspicious, but have no way to bypass the block. You are blocking a number of sites I need access to, and I have no intention of submitting them to you to review or approve, I want them, I need them, you need to let me bypass the block. This is completely unacceptable.
I just finally got the system all set up the way I like, but I'm about to return it, because this is a deal breaker... YOU NEED TO FIX THIS QUICKLY!edit: sorry I was getting really upset about this because I'm on a time crunch and things were blocked. I figured out in the orbi app, it notfies that it blocked sites, if you click on the notification there is the option to unblock.
It is still a bit ridculous that I cant just click procced on the web page, and I didn't have my phone near or think about looking on the phone to unblock sites Im working on on my main PC.
DexterJB
Jun 07, 2019NETGEAR Moderator
Hi shawn007, your feedback is greatly appreciated. I have forwarded it to the team for their consideration.
Dexter
lwgold
Feb 15, 2020Initiate
It is so sad that Netgear Armor is blocking my company website(s). I don't have the time to wait for BitFinder to whitelist it. I need the option on my Nighthawk R7000 to enter my own sites that I want/need whitelisted
- PlumbuddleFeb 15, 2020StarJust dump the product. I did and it solved everything.
- jstuffApr 12, 2020Initiate
I've only had mine for a week. The mesh has improved network performance in the house, so I really want to like this. But it's URL blocking is TERRIBLE. It needs to allow for bypass after warning or whitelisting or both. I think I may be just returning the Netgear Orbi and going with a different product. Terrible design.
- Christian_RApr 14, 2020NETGEAR Employee Retired
Hello jstuff,
Please check out the article below on how to unblock URLs in Armor.
https://kb.netgear.com/000061715/How-do-I-unblock-URLS-in-NETGEAR-Armor
Christian
