jagert
Aug 10, 2021Follower
Netgear Armor will nor allow WEMO devices to work on my LAN
After installing Netgear Armor, my WEMO devices can not be accessed on my LAN.
Without Armor, they work. Is there a solution for this problem, other than getting rid of Netgear Armor?
1 Reply
- Christian_RNETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
