stanfrench
Oct 13, 2024Luminary
Netgear Armor won't load on Mac
The Netgear Armor app doesn't load on my iMac (macOS Ventura) or Macbook (macOS Sequoia). I can install it ok, but when I try to open the app, I just get a page asking me to "Allow all security modul...
- Oct 26, 2024
My faith in Netgear and more, in Bitdefender has been restored. I had an online troubleshooting session with one of the Bitdefender technical reps (Vlad) and he was able to get the Netgear Armor app to fully open and function on both my Macbook Pro M2 (running Sequoia) and my iMac (running Ventura).
I tried to watch what he was doing and it seems the location where he got the installation package from was a bit different from where I was getting it. After uninstalling everything (including VPN), he then went to the site link armor.netgear.com/dashboard. He downloaded the installation package from the Dashboard tab. There is a tile on the top left side of the "Security Dashboard" page which is called "My devices". From there he selected "Install NETGEAR Products" and waited for the package to download. Then he installed and it worked.
If you still run into problems, I suggest you arrange an online troubleshooting session with Bitdefender tech reps (not Netgear, they'll just ask you to reset your router). You might need to open a support ticket first.
Good luck! I'm a happy camper now
DarrenM
Oct 17, 2024Sr. NETGEAR Moderator
Hello Stan
This app is only made for iOS and Android. Though it may run on a Mac, it is not fully supported on a Mac.
Thanks
DarrenM
stanfrench
Oct 18, 2024Luminary
Hi Darren,
Take a look at the attached PDF of the download and installation screenshots. This is only for iOS? It sure doesn't look like it to me. I've installed a lot of apps and programs for my iMac and Macbook, and this looks as official and intentional as the others.
