greddyuk's avatar
greddyuk
Netgear Armor
I currently own a RAX120, i have two questions i dont know have to setup:-
Question 1: How to a create a separate wifi line?
I currently have my main wifi connected to all my security at home. I want to create a separate SSID line for all NON security appliance. How do i create a separate SSID? is this possible?
I am currently using my "guest" line and i dont think its the correct method.
Question 2:- Im planning to purchase internet security. Does the RAX120 support Netgear Armor? How do you rate the safety of Netgear Armor? is it any good?
Thanks
  • AbhayB's avatar
    AbhayB
    NETGEAR Employee Retired
    Thanks
    Hi greddyuk ,
    Answer 1: Currently Guest network is the only way to use a seperate SSID for non security appliances. Only limitation is that these devices won't be able to access other devices on the local network if you need. For example, sometimes a lot of apps need your phone and such IOT devices to be on same WiFi network.
    Answer 2: RAX120 currently does not support NETGEAR Armor. NETGEAR Armor is powered by Bitdefender's award-winning smart home platform and is ideal for provinding overall cybersecurity for your entire network.
    • greddyuk's avatar
      greddyuk
      Thank you for your answer.
      I rather surprised their top of the range router does not support a service which would make them more money.
      I have read that it’s possible that this router is capable of having multiple SSID and yet somewhat disappointing to know it’s not possible - especially paying so much for their product. It’s a expensive mistake to have.
