cuse165
Feb 13, 2020Aspirant
NETGEAR Armor
I am having issues with Netgear Armor. Webpages not loading to not being able to access the website if you lost your phone. So my question is any support from Netgear or do I contact Bitdefender Supp...
- Feb 21, 2020
Hello cuse165,
When you get a chance, may you visit armor.netgear.com again and let us know if you're still experiencing the same issue.
Thanks!Christian
cuse165
Feb 18, 2020Aspirant
Thank you very much any information would be appreciated.
I reset my router to factory state thinking that might help. It did not help I just think it's the webpage.
Christian_R
Feb 21, 2020NETGEAR Employee Retired
Hello cuse165,
Thanks!
Christian
- cuse165Feb 21, 2020AspirantThe page comes up in a error now. Video https://1drv.ms/v/s!AtxxebpM5QtOgs0F3ODxnXZ-bRJMmQ same thing on a pc.
- cuse165Feb 21, 2020AspirantI used a different browsers the webpage works now but the first issue is still happening.
- Christian_RFeb 21, 2020NETGEAR Employee Retired
Hi cuse165,
May you try rebooting your router and letting me know if there are any improvement. On my RBR50 here, I'm able to access the armor.netgear.com portal without the spinning circle issue.
Thanks,
Christian
