smackmick
Dec 15, 2019Aspirant
Netgear Armour issue with Frontpoint camera
I just updated to the AC1750 router, and I used the same SSID and password so all my devices would reconnect. Everone did but the new Frontpoint camera. I could get the camera to the attach to netw...
DexterJB
Dec 16, 2019NETGEAR Moderator
Hi smackmick, welcome to the community! Are you referring to the camera being detected by Armor and logged as an attached device when you go to armor.netgear.com? Also, is this where you deleted the entry?
Dexter
- smackmickDec 16, 2019Aspirant
I was in the online admin for the router, it had a button to take me to the Armour site where I could see all the devices it had registered. So there is a place at the end you can remove, and then when I set up my camera again and it connected to the router, it logged it again as new.
- DexterJBDec 17, 2019NETGEAR Moderator
Hi smackmick, thanks for responding and for the confirmation. Yes, that is part of the device detection feature of Armor. You can read more on that on the link below.
https://kb.netgear.com/000059522/What-is-NETGEAR-Armor-device-detection-and-how-does-it-work
Dexter
- smackmickDec 18, 2019Aspirant
Yes letting me know a new device has been added is good, what this point was about was a device was trying to register to an existing entry, and Armour did nothing. If someone were trying to spoof, the tool should have alerted me to the issue. It did nothing, including not attaching which is extremely hard to debug.
- DexterJBDec 18, 2019NETGEAR Moderator
Thank you for clarifying. We'll have this forwarded to the team for them to check.
Dexter
