gazorn
May 18, 2023Aspirant
Netgear Armour unable to unblock access
IOS 16.4 and 16.5 App Version 2.26.0.61 RBR750 Firmware V4.6.14.3 Cannot unblock a web address, see screenshot Can we get a fix or is it time to drop Netgear Armour?
- May 23, 2023
It is not the easiest solution to find. You need to log into https://armor.netgear.com
and then click on the bell in the top left corner to see blocked addresses. From there you can allow access.
May 22, 2023Guru - Experienced User
Did you select "Learn More" link in the app message below?
- gazornMay 22, 2023Aspirant
Yes. Had to finally figure how to use the website on my desktop to allow the address.
- FURRYe38May 23, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- gazornMay 23, 2023Aspirant
