gazorn
May 18, 2023Aspirant
Netgear Armour unable to unblock access
IOS 16.4 and 16.5 App Version 2.26.0.61 RBR750 Firmware V4.6.14.3 Cannot unblock a web address, see screenshot Can we get a fix or is it time to drop Netgear Armour?
- May 23, 2023
It is not the easiest solution to find. You need to log into https://armor.netgear.com
and then click on the bell in the top left corner to see blocked addresses. From there you can allow access.
gazorn
May 22, 2023Aspirant
Yes. Had to finally figure how to use the website on my desktop to allow the address.
May 23, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- gazornMay 23, 2023Aspirant
- Mark67Jun 01, 2023Aspirant
I have the Nighthawk R6400v2 router extender. Armor expired. I cannot find any buttons to unblock devices in the netgear site, Nighthawk site, or Armor site. Tried a few of the recommendations. Any ideas?
- FURRYe38Jun 01, 2023Guru - Experienced User
Factory reset the router and setup from scratch with a wired PC and web browser. Don't enable Armor after setting up.
