gazorn
May 18, 2023Aspirant
Netgear Armour unable to unblock access
IOS 16.4 and 16.5 App Version 2.26.0.61 RBR750 Firmware V4.6.14.3 Cannot unblock a web address, see screenshot Can we get a fix or is it time to drop Netgear Armour?
- May 23, 2023
It is not the easiest solution to find. You need to log into https://armor.netgear.com
and then click on the bell in the top left corner to see blocked addresses. From there you can allow access.
gazorn
May 23, 2023Aspirant
Mark67
Jun 01, 2023Aspirant
I have the Nighthawk R6400v2 router extender. Armor expired. I cannot find any buttons to unblock devices in the netgear site, Nighthawk site, or Armor site. Tried a few of the recommendations. Any ideas?
- FURRYe38Jun 01, 2023Guru
Factory reset the router and setup from scratch with a wired PC and web browser. Don't enable Armor after setting up.
