StringZ
Jun 30, 2021Tutor
Netgear is blocking a streaming site which I want to watch,
I have a RAX80 with Netgear Armor running. I have streaming subscription but it block some streams. It doesnt matter whether I use my ipad, meadia player or phone they are all blocked. ...
Jul 02, 2021Guru - Experienced User
Does it work fine if you disable Armor?
NETGEAR Armor is blocking URLs that I want to access; what do I do? | Answer | NETGEAR Support
- StringZJul 03, 2021Tutor
I havent disable yet. It starting working after I sent the sites to
https://www.bitdefender.com/consumer/support/answer/40673/
Thanks for the help
- plemansJul 03, 2021Guru - Experienced User
Glad its working again either way!
