Phi-Bui
Mar 24, 2023Aspirant
Netgear Mesh MR70 Blocking Websites
I just got the mesh MR70 and Armor installed. Everything works great with the exception that it's blocking certain "legit" websites, such as Tesla.com. I disabled Armor and it still doesn't work. ...
Mar 24, 2023Guru - Experienced User
After disabling Armor in the NH app, did you power OFF the MR and ISP modem for 1 minute then back ON?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Phi-Bui
Thank you for responding.
Yes, after I disabled Armor. I did power the router down and up again. It's still not working. I'm using the latest firmware. I even went to the support site and download the latest to make sure. The firmware version I have is V1.0.3.32_2.0.57. As far as the cable, I used the one that comes with MR70.
I even went further and reset everything, re-installing MR70 and it still didn't do it. Prior to MR70, I had R6700 which has no problem accessing any websites. I'm running out of things to try. Worst case scenario, I'll return the product.
- Phi-BuiMar 26, 2023Aspirant
I just found out that it also blocks www.southwest.com. I'm ready to return this product!!!
