Phi-Bui
Mar 24, 2023Aspirant
Netgear Mesh MR70 Blocking Websites
I just got the mesh MR70 and Armor installed. Everything works great with the exception that it's blocking certain "legit" websites, such as Tesla.com. I disabled Armor and it still doesn't work. ...
Phi-Bui
Thank you for responding.
Yes, after I disabled Armor. I did power the router down and up again. It's still not working. I'm using the latest firmware. I even went to the support site and download the latest to make sure. The firmware version I have is V1.0.3.32_2.0.57. As far as the cable, I used the one that comes with MR70.
I even went further and reset everything, re-installing MR70 and it still didn't do it. Prior to MR70, I had R6700 which has no problem accessing any websites. I'm running out of things to try. Worst case scenario, I'll return the product.
Phi-Bui
Mar 26, 2023Aspirant
I just found out that it also blocks www.southwest.com. I'm ready to return this product!!!
- Razor512Mar 26, 2023ProdigyWere you able to check the time zone as well as finding any info about how the error looks? That may help to get a better understanding of what exactly is happening.
- Phi-BuiMar 26, 2023AspirantYes, the time zone is correct. The fingerprint is also correct.
- Phi-BuiMar 28, 2023Aspirant
I gave up on this setup. I went to COSTCO and got the RB750. Everything went great last night. I was able to access all the websites. This morning, I ran into the same issues with NO CHANGE to the router.
I'm ready to give up on NETGEAR. I tried two different products and getting the same error. I was on the phone with NETGEAR tech support for 3 days and nothing got resolved. I can't imagine I'm the only one with this issue. Time to switch. I'll return both products MESH MR70 and ORBI 750. I'm done!!!
