Don-O
Nov 13, 2021Guide
NETGEAR Nighthawk AXE11000 Tri-band WiFi 6E Router (RAXE500)
I have a new RAXE500. It works great except when I turn on the on Armor. If I turn on Armor then the router works for about 7 to 24 hours and then jams up the internet...almost like we had turned o...
Don-O
Nov 14, 2021Guide
Thank you I will try these options and let you know.
Thank you so very much for your prompt and detailed reply.
Don
Altsai
Dec 15, 2021NETGEAR Expert
Do you still see the issue?
- Don-OFeb 12, 2022Guide
All better now... The router works perfectly.
I called my cable company and they were already in the process of upgrading from the Zizel router to having everyone use thier own router with either a Apple TV or FireStick with an App that we can direct stream from.
Bottom line they took their router out so my Nighthawk is the only router. That was the problem....two routers inline.
They came in last week and took out the Zizel box (router)... and I am now able to connect my router directly into the Internet without a second router inline.
I have turned on my Armor and absoluetly no problems over the past week.
Thank you all so very much for your help.
DonO
- plemansFeb 12, 2022Guru - Experienced User
glad it took care of it!
If you mark it solved, it might keep others from trying to solve it :)
