BleachX
Apr 25, 2025Tutor
Netgear-RS700
My Netgear-RS700 Armor software seems to constantly tell me that my Google WiFi has been scanned and no issues are found, yet I get messages that Google WiFi was bocked trying to connect to random s...
Apr 25, 2025Guru - Experienced User
Are you running two Wi-Fi router systems? RS and Google Wi-Fi?
- BleachXApr 25, 2025Tutor
Correct
- FURRYe38Apr 25, 2025Guru - Experienced User
How big is your home?
The RS router should work alone with out any additional wifi support.
If you need more support, could configured the 2nd system for AP mode instead of router mode would help some.
If turning OFF the 2nd system do same message appear in Armor?
The home is just over 4,000sq ft. I use the RS for some things and the Google WiFi for others. They work fine together, different IP space and SSID's. This only started with the new RS router. I had a previous Netgear router before and never saw this.
